Processeur trop sollicité
Messagede maxou45 » 20 Nov 2017 17:01
Refais moi un zhpdiag stp
Messagede Oihana » 20 Nov 2017 17:23
Oihana
Résolution d’écran: 1440 x 810 1440 x 810
Messagede maxou45 » 20 Nov 2017 18:28
opt:O4 - HKCU\..\Run: [DashlanePlugin] . (.Dashlane, Inc. - Dashlane.) -- C:\Users\Sylvie\AppData\Roaming\Dashlane\DashlanePlugin.exe
opt:O4 - HKCU\..\Run: [Google Update] . (. - .) -- C:\Users\Sylvie\AppData\Local\Google\Update\1.3.33.7\GoogleUpdateCore.exe
opt:O4 - HKCU\..\Run: [F66B25BF52D765BDB7FB1FD7569ED37D20F589E8._service_run] . (.Google Inc. - Google Chrome.) -- C:\Users\Sylvie\AppData\Local\Google\Chrome\Application\chrome.exe
opt:O4 - HKCU\..\Run: [ClipCube] . (...) -- D:\UTILITAIRES\ClipCube\ClipCube.exe
opt:O4 - HKLM\..\Wow6432Node\Run: [StartCCC] . (.Advanced Micro Devices, Inc. - Catalyst® Control Center Launcher.) -- C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\amd64\CLIStart.exe
opt:O4 - HKLM\..\Wow6432Node\Run: [HDAudDeck] . (.VIA - VIA HD Audio CPL.) -- C:\Program Files (x86)\VIA\VIAudioi\VDeck\VDeck.exe
opt:O4 - HKLM\..\Wow6432Node\Run: [SunJavaUpdateSched] . (.Oracle Corporation - Java Update Scheduler.) -- C:\Program Files (x86)\Common Files\Java\Java Update\jusched.exe
O4 - GS\sendTo [Administrateur]: Foxmail.LNK . (.Tencent Inc. - Foxmail 7.0.) D:\UTILITAIRES\fm70chb1_93_fr\Foxmail.exe /min
O4 - GS\sendTo [Sylvie]: Foxmail.LNK . (.Tencent Inc. - Foxmail 7.0.) D:\UTILITAIRES\fm70chb1_93_fr\Foxmail.exe /min
O108 - CMH3: 00avast [64Bits] - {472083B0-C522-11CF-8763-00608CC02F24} . (.Orphan.)
O108 - CMH5: Gadgets [64Bits] - {6B9228DA-9C15-419e-856C-19E768A13BDC} . (.Orphan.)
C:\Users\Sylvie\AppData\Roaming\Mozilla\Firefox\Profiles\not3glmd.default\extensions\pavel.sherbakov@gmail.com.xpi
HKLM\Software\Classes\AllFileSystemObjects\ShellEx\ContextMenuHandlers\00avast
Messagede Oihana » 20 Nov 2017 19:46
Voilà le rapport ZHPFix :
Rapport de ZHPFix 2017.06.13.1 par Nicolas Coolman, Update du 13/06/2017
Fichier d'export Registre : C:\Users\Sylvie\AppData\Roaming\ZHP\ZHPExportRegistry-20-11-2017-19-39-05.txt
Run by Sylvie at 20/11/2017 19:38:59
High Elevated Privileges : OK
Windows 8 Home Premium Edition, 64-bit Service Pack 1 (15063)
Corbeille vidée (Annulé par l'utilisateur)
Dossier Prefetcher vidé
========== Processus mémoire ==========
SUPPRIMÉ: Memory Process: C:\Users\Sylvie\AppData\Roaming\Mozilla\Firefox\Profiles\not3glmd.default\extensions\pavel.sherbakov@gmail.com.xpi
========== Clés du Registre ==========
SUPPRIMÉ: HKLM\Software\Classes\AllFileSystemObjects\ShellEx\ContextMenuHandlers\00avast
========== Valeurs du Registre ==========
SUPPRIMÉ RunValue: DashlanePlugin
SUPPRIMÉ RunValue: Google Update
SUPPRIMÉ RunValue: F66B25BF52D765BDB7FB1FD7569ED37D20F589E8._service_run
SUPPRIMÉ RunValue: ClipCube
SUPPRIMÉ RunValue: StartCCC
SUPPRIMÉ RunValue: HDAudDeck
SUPPRIMÉ RunValue: SunJavaUpdateSched
Aucune Valeur Standard Profile: FirewallRaz :
Aucune Valeur Domain Profile: FirewallRaz :
SUPPRIMÉ: FirewallRaz (None) : MCX-Prov-Out-TCP
SUPPRIMÉ: FirewallRaz (None) : MCX-McrMgr-Out-TCP
SUPPRIMÉ: FirewallRaz (None) : WCF-NetTcpActivator-In-TCP-64bit
SUPPRIMÉ: FirewallRaz (Private) : {328B6C0E-6E7E-433C-8F5B-B8EE6DEEBD33}
SUPPRIMÉ: FirewallRaz (Private) : {EAAF79EC-F03C-4388-99F7-2F610E062DAC}
SUPPRIMÉ: FirewallRaz (Private) : UDP Query User{72A98947-AFAD-489D-AF73-750ECE0B2596}C:\program files (x86)\musicbrainz picard\picard.exe
SUPPRIMÉ: FirewallRaz (Private) : TCP Query User{4BA8B77C-2802-411F-9815-5D47B66EE4BC}C:\program files (x86)\musicbrainz picard\picard.exe
SUPPRIMÉ: FirewallRaz (Private) : UDP Query User{FB1AC653-1A06-4055-A448-DCBA0BC6E539}C:\program files (x86)\videolan\vlc\vlc.exe
SUPPRIMÉ: FirewallRaz (Private) : TCP Query User{5F03FBB3-867F-4AAD-890F-A40B22B15DB4}C:\program files (x86)\videolan\vlc\vlc.exe
SUPPRIMÉ: FirewallRaz (Public) : UDP Query User{1B2A6308-B10D-47E8-9E5C-3F5E9406E9D0}C:\users\sylvie\appdata\roaming\dropbox\bin\dropbox.exe
SUPPRIMÉ: FirewallRaz (Public) : TCP Query User{415DDF33-63C3-4F69-B119-1763D368FE8A}C:\users\sylvie\appdata\roaming\dropbox\bin\dropbox.exe
SUPPRIMÉ: FirewallRaz (Private) : {02BD2D98-C0CE-4F09-8168-43BA6EE7845B}
SUPPRIMÉ: FirewallRaz (Private) : {D6645CBD-081B-4B59-A209-416BF9AE76D9}
SUPPRIMÉ: FirewallRaz (Private) : {D506C5D8-D647-4FA5-AF9B-3A6A07F9C037}
SUPPRIMÉ: FirewallRaz (Private) : {68212CAA-5AEC-425A-9DD7-1571234E013B}
SUPPRIMÉ: FirewallRaz (Private) : {92ECAC59-3873-471B-AE88-C02E56274844}
SUPPRIMÉ: FirewallRaz (Private) : {04267761-A7C9-4839-9B1C-A3C9060EB19A}
SUPPRIMÉ: FirewallRaz (Private) : {F5641C4D-E965-4D19-81C5-1847A3ACE4A9}
SUPPRIMÉ: FirewallRaz (Private) : {2695D78B-CA07-48C0-9DDE-2350486183DD}
SUPPRIMÉ: FirewallRaz (Private) : TCP Query User{CCB82C9D-389A-4979-8C30-833529C44A10}C:\program files (x86)\calibre2\calibre.exe
SUPPRIMÉ: FirewallRaz (Private) : UDP Query User{7ADA8C68-1310-45DB-A963-569C2218126B}C:\program files (x86)\calibre2\calibre.exe
ProxyFix : Configuration proxy supprimée avec succès
SUPPRIMÉ ProxyServer Value
SUPPRIMÉ ProxyEnable Value
SUPPRIMÉ EnableHttp1_1 Value
SUPPRIMÉ ProxyHttp1.1 Value
SUPPRIMÉ ProxyOverride Value
SUPPRIMÉ: C:\Users\Sylvie\AppData\Local\{2694770B-BDB0-43BD-9B84-BE9BA3CADE94}
SUPPRIMÉ: C:\Users\Sylvie\AppData\Local\{F8AC2AB2-9F6C-4C16-8478-CD2921E2DB93}
========== Fichiers ==========
SUPPRIMÉ:** c:\users\sylvie\appdata\roaming\mozilla\firefox\profiles\not3glmd.default\extensions\pavel.sherbakov@gmail.com.xpi
SUPPRIMÉS Temporaires Windows (0) (0 octets)
SUPPRIMÉS Flash Cookies (0) (0 octets)
1 : Processus mémoire
1 : Clés du Registre
36 : Valeurs du Registre
2 : Dossiers
3 : Fichiers
1 : Restauration Système
End of clean in 01mn 08s
C:\Users\Sylvie\AppData\Roaming\ZHP\ZHPFix[R1].txt - 12/09/2015 22:41:05 [2889]
C:\Users\Sylvie\AppData\Roaming\ZHP\ZHPFix[R2].txt - 20/11/2017 19:39:05 [10418]
Oihana
Messagede maxou45 » 20 Nov 2017 20:24
redemarre et dis moi ce que ca donne
Messagede Oihana » 20 Nov 2017 21:34
J'avais déjà redémarré, aucune amélioration.
Processeur à 97 et internet lent.
Oihana
Messagede maxou45 » 21 Nov 2017 10:47
Alors regarde dans le gestionnaire des taches quel est le processus qui te prend autant de ressources
Messagede Oihana » 21 Nov 2017 14:16
Les 3 postes les plus gourmands (sachant que les pourcentages fluctuent constamment) :
- Hôte de Service : Partage de connexion internet (ICS) : 11 à 20 % (semble s'être stabilisé autour de 11 depuis que j'ai allumé le PC vers 12h))
- Hôte de Service : Service Réseau (aucun réseau) (3) : 14 à 22 % (était à 30 % vers 12h)
Comprend : CoreMessaging, Moteur de filtrage de base, Pare-feu Windows
- Système : 22 à 28 %
A cela s'ajoute Firefox : 10 à 26 % (1 seul onglet ouvert)
Les 2 premiers postes changent beaucoup : ils baissent puis remontent (surtout le 2ème). Le système reste constant dans la même fourchette.
Au final, avec ou sans Firefox ouvert, le processeur est toujours autour de 90 %, 98 % actuellement.
Oihana
Messagede maxou45 » 21 Nov 2017 15:49
ca me semble tout a fait correcte ces valeurs
sachant qu'il suffit de bouger la souris pour faire monter a 98% ... mais c'est l'activité du microprocesseur , ca n' a rien a voir avec la memoire
Et ca tu n'y peux rien, tu n'es pas infecté
essaie ceci
  • Télécharge Windows repair
  • Installe-le (Vista/Win7 et Win8 --> clic droit et "Exécuter en tant qu'administrateur")
    ::!: Avant de passer à la suite, désactive provisoirement tes logiciels de protection (ils peuvent gêner la/les réparations) ::!:
  • Exécute Windows Repair (Vista/Win7 et Win8 --> clic droit et "Exécuter en tant qu'administrateur")
  • Clique directement sur l'onglet Step5:Backup
  • Sous System Restore, clique sur Create (pour créer un point de restauration)
  • Patiente quelques secondes jusqu'à affichage de l'indication "Restore Point created at..."
  • Clique ensuite sur la flèche suivante
  • A l'onglet + Repairs, coche "Automatically di a registry backup" puis clique sur Open Repairs
  • Dans la fenêtre suivante :
    1. Laisse les cases cochées comme elles sont
    2. Coche la case Restart/shutdown system when finished et Restart System
    3. Clique sur Start Repair pour démarrer la réparation
  • Patiente le temps de la réparation
  • Après redémarrage du PC, récupère le rapport de réparation à cet emplacement : C:\Program Files\Tweaking.com\Windows Repair (All in One)\logs\_Windows_repair.log
Messagede Oihana » 21 Nov 2017 17:07
Le téléchargement ne m'a pas donné la même version que sur tes captures d'écran.
Il n'y a pas d'onglet 5 Backup. Par contre, il y a un onglet "Backup Tools" qui me propose ça :
Je clique sur le Backup de Registry Backup ?
Oihana
Messagede Oihana » 21 Nov 2017 17:15
Ah ben non, ça doit être Create sous System Restore, que je suis bête :doh:
J'attends quand même que tu confirmes.
Oihana
Messagede maxou45 » 21 Nov 2017 17:58
la version a dû evoluer, je regarde
edit:
c'est dans repair-main
open repair
tu coches tout
start repairs
Messagede Oihana » 21 Nov 2017 22:51
Réparation enfin terminée et ça a marché, ouf ! Processeur maintenant dans les 40 % et quasiment à 0 si je ne fais rien.
Le rapport : http://www.cjoint.com/c/GKvvEY8MEgQ
Merci beaucoup pour ton aide, Maxou !
Dois-je conserver Windows Repair, en cas de besoin ?
Oihana
PrécédenteSuivante
Utilisateurs parcourant ce forum: dadgolfi, maxou45 et 2 invités
