[Résolu 27/08/17] écran de saisie du mot de passe
Messagede maxou45 » 20 Aoû 2017 21:32
super
refais moi un zhpdiag
Messagede jeanlucdescot » 20 Aoû 2017 23:20
Ci dessous le rapport.
https://up2sha.re/file?f=55E6JA3R
jeanlucdescot
Firefox 55.0 Firefox 55.0
Messagede maxou45 » 21 Aoû 2017 03:58
O39 - APT: avast! Emergency Update - (...) -- C:\WINDOWS\System32\Tasks\avast! Emergency Update [3160] (.Orphan.)
O39 - APT: RealUpgradeLogonTaskS-1-5-21-2564878898-3060027615-1487160507-1000 - (...) -- C:\WINDOWS\System32\Tasks\RealUpgradeLogonTaskS-1-5-21-2564878898-3060027615-1487160507-1000 [2450] (.Orphan.)
O39 - APT: RealUpgradeScheduledTaskS-1-5-21-2564878898-3060027615-1487160507-1000 - (...) -- C:\WINDOWS\System32\Tasks\RealUpgradeScheduledTaskS-1-5-21-2564878898-3060027615-1487160507-1000 [2542] (.Orphan.)
O39 - APT: SidebarExecute - (...) -- C:\WINDOWS\System32\Tasks\SidebarExecute [2090] (.Orphan.)
O39 - APT: {1B35E0F1-1450-446B-A1CD-40CBEDA5CAF0} - (...) -- C:\WINDOWS\System32\Tasks\{1B35E0F1-1450-446B-A1CD-40CBEDA5CAF0} [2320] (.Orphan.)
O39 - APT: {5B3126E6-2BB4-4763-82C5-29A3A7EB8FEF} - (...) -- C:\WINDOWS\System32\Tasks\{5B3126E6-2BB4-4763-82C5-29A3A7EB8FEF} [2124] (.Orphan.)
O39 - APT: {B5A814CE-6D71-463D-9326-A23FD64E8732} - (...) -- C:\WINDOWS\System32\Tasks\{B5A814CE-6D71-463D-9326-A23FD64E8732} [2298] (.Orphan.)
O2 - BHO: Java(tm) Plug-In SSV Helper [64Bits] - {761497BB-D6F0-462C-B6EB-D4DAF1D92D43} (.Orphan.)
O2 - BHO: Java(tm) Plug-In 2 SSV Helper [64Bits] - {DBC80044-A445-435b-BC74-9C25C1C588A9} (.Orphan.)
[HKLM64\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}]
[HKLM\Software\Classes\CLSID\{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}]
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}]
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{761497BB-D6F0-462C-B6EB-D4DAF1D92D43}]
[HKLM64\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Browser Helper Objects\{DBC80044-A445-435b-BC74-9C25C1C588A9}]
[HKLM\Software\Classes\CLSID\{DBC80044-A445-435b-BC74-9C25C1C588A9}]
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats\{DBC80044-A445-435b-BC74-9C25C1C588A9}]
[HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Settings\{DBC80044-A445-435b-BC74-9C25C1C588A9}]
O42 - Logiciel: QuickTime 7 - (.Apple Inc..) [HKLM][64Bits] -- {FF59BD75-466A-4D5A-AD23-AAD87C5FD44C}
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{FF59BD75-466A-4D5A-AD23-AAD87C5FD44C}
HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{FF59BD75-466A-4D5A-AD23-AAD87C5FD44C}
Messagede jeanlucdescot » 21 Aoû 2017 08:15
ci dessous le rapport.
https://up2sha.re/file?f=P9opH7wV
jeanlucdescot
Messagede maxou45 » 21 Aoû 2017 08:35
Redemarre et dis moi ce que ca donne
Messagede jeanlucdescot » 21 Aoû 2017 08:44
Tout se passe bien.
jeanlucdescot
Messagede maxou45 » 21 Aoû 2017 08:45
Plus de soucis de saisie du mot de passe au demarrage ?
on peut cloturer ce post ?
Messagede jeanlucdescot » 21 Aoû 2017 08:58
Je pense que le post peut être clôturé.
Comment faire machine arrière des consignes expliquées dans le tutoriel ci-dessous ?
https://forum-windows7-windows8.fr/viewtopic.php?f=37&t=2763
jeanlucdescot
Messagede maxou45 » 21 Aoû 2017 10:01
Tu recommences la manip, mais a cette page tu coches la case
"les utilisateurs doivent entrer ...."
je solde le sujet
Messagede jeanlucdescot » 21 Aoû 2017 18:31
OK merci.
Juste avant de faire la manipulation qui exige la saisie du mot de passe , j'ai à nouveau été dans impossibilité de faire quoique ce soit sur mon PC. J'ai "forcé un redémarrage" ...
jeanlucdescot
Messagede maxou45 » 21 Aoû 2017 19:28
Nous allons lire les fichiers d'erreur
  • Télécharge sur le bureau GetSystemInfo.exe Image (de Kaspersky)
  • Lance-le par clic-droit -> Exécuter en tant qu'administrateur
  • Accepte les conditions d'utilisations,
  • Clique sur Settings, puis sur Customize, ouvre tous les onglets (5) et à chaque fois coche toutes les cases,
  • Clique sur OK (deux fois)
  • Clique sur Create report
  • L'outil va travailler pendant quelques minutes,
  • Une fenêtre s'ouvrira : clique sur [Send]
  • Ton navigateur s'ouvrira,
  • Fais clic-droit -> Copier sur l'adresse générée
  • Colle cette adresse dans ta prochaine réponse.
Messagede jeanlucdescot » 21 Aoû 2017 22:26
jeanlucdescot
Messagede jeanlucdescot » 21 Aoû 2017 22:28
Je me suis planté ,merci d'oublier le message précédent
jeanlucdescot
PrécédenteSuivante
Utilisateurs parcourant ce forum: Aucun utilisateur enregistré et 5 invités
